Old 26-Sep-2013, 00:32   #1
donvittorioc donvittorioc is offline
Dynojet Push Quickshifter - For Any Power Commander 3 Equipped Motorcycle - Price 80£
Genuine Dynojet Push Quickshifter - For Any Power Commander 3 Equipped Motorcycle - Price 80£
Used On A Ducati 996 And Works As It Should.
Sticker Has Worn Out Due To Slight Rubbing.
Can Collect From Central London If You Like Or Belvedere Kent. 07896891906 Call Or Message For Any Queries.
I Can Post It For 5£ At Buyer Expense.
Can Also Be Very Easily Adapted For A Power Commander 5 By Cutting The Plug Off And Using The Blue And Green Wire Into Your Pcv
Look At Your Gearshift Linkage.simulate A Shift From 1st - 2nd And Verify This Is The Correct Shifter For You.
This Unit Work By Basically Cutting The Fuel To Both Sets Of Injectors For A Split Second Once Sufficient Strain Is Detected On The Quickshift Module. At The Point Which Your Foot Is Lifting The Gear Lever The In Line Shift Module Operates A Pressure Sensitive Switch. That Tells The Power Commander To Cut The Fuel For About 1 1/2 Cycles Of Your Engine. The Instant The Gearbox Is Unloaded The Pressure From Your Foot On The Gear Selector Engages The Next Gear. All This Happens In An Instant And All You Hear Is An Instant Drop In Revs As The Bike Changes Up The Gearbox.
Price Is 80£. This Cost Over 200£ New
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:00.
