Old 24-Dec-2005, 19:12   #1
weeksy2 weeksy2 is offline
748 Exhaust removal and swap.
Alright gents, this is the next project to run alongside the cleaning and prepping of the 916 and that's to fit the new race cans to the Mrs' 748s.
So, i'm unsure as to the process/plan.
It's only a 45mm pair of cans so will be going striaght onto the current headers.
Do i need to remove the subframe to allow to lift the cans enough ? or can i just removed the springs, straps and turn them outwards to then raise them ?
Cheers in advance guys.
Old 24-Dec-2005, 19:15   #2
keefer keefer is offline
keefer's Avatar
just undo the numberplate and the bottom two bolts on the sub frame.
you can then leaver it up enough to lift of the pipes.
that's about it
Old 24-Dec-2005, 19:20   #3
that's about it
You need a gasket type paste for the joining pieces when putting back together ?
Old 24-Dec-2005, 19:22   #4
keefer's Avatar
shouldn't do.
I never used one.
however I remember seeing shazam say that gaps can cause backfire. ?
have a look and see if there is any residue when you take em off
Old 24-Dec-2005, 19:23   #5
GsxrAge GsxrAge is offline
GsxrAge's Avatar
Just undo the springs mate and they will come off. There is no need to remove antthing else.
Old 24-Dec-2005, 19:24   #6
no...so easy even I can do it!! bit fiddley getting the rubber thing on that holds the end cans in place, and if the cans are tight to get off then a hairdryer may be handy (was with mine) to warn the pipe a bit and make it easier to move...just unbolt and replace
but shouldnt you be singing and drinking beers by now??? LOL
Old 24-Dec-2005, 19:26   #7
thanks lads.... no beer and stuff tonight. Up in St Davids for Xmas with Mrs' familly... rather quiet and sophisticated...
As you can imagine, i fit right in !!!!!!
Old 25-Dec-2005, 17:24   #8
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
I find the springs a right B*****d to clip back on, apparently there is a spring pulling tool you can buy. I normally use a pair of pliers and settle for cut knuckles also.
Old 25-Dec-2005, 18:34   #9
Dont use pliers............ use a length of speaker wire. Hook one end on the exhaust work our where you want the other end to go..........and pull it with the wire looped through it!
Old 25-Dec-2005, 18:51   #10
GsxrAge's Avatar
I made up my own hook.
remove the rear pillion peg brackets. remove the small bolt holding the two cans together, then undo the top bolts on the bracket (8mm)remove springs and twist the right hand pipe outwards Just becarefull when removing the right hand pipe it will be very close to the pillion bracket bolt hole on the sub frame.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:01.
