Old 26-Sep-2013, 14:17   #1
knappers knappers is offline
SS 916 Cafe Hybrid
Been trying to build a bike out of bits, managed to get
this thing together, sort of. Had some good info off you
guys especially Cornerspeed its running now but need more please.
916 frame, 2 valve engine standard alloy swing arm.
Think its got the lighter front wheel. 916 tank, seat unit no fairing.
Its been running open carbs, rubber trumpets no filters 148 main jet.
I'm guessing the lower shock mount should have a
spherical bearing (not plain?) with top hat bushes??
This one looks to have been bodged, someone using
washers between the shock bearing (plain) and swing arm
mount. Found them after I removed shock (had to make a
stand first to get it off the ground) to check valves.
Taking me a long time to get it done because I had an
off resulting in broken vertebrae, abscess 3 years ago,
but that's another story.
Thanks for any info
Old 26-Sep-2013, 17:14   #2
Are there meant to be some pics or a link
Old 26-Sep-2013, 19:58   #3
Oddly enough, I was only trying to find a thread on a 916/SS a few weeks ago and managed to find it:
http://www.speedzilla.com/forums/duc...ilt-91-ss.html
As for the swingarm bearing, I thought it was a plain sleeve but its been too long since I worked on my bike as this parts page shows:
Old 26-Sep-2013, 22:12   #4
Been trying to, tells me they're too big to upload
Old 26-Sep-2013, 22:23   #5
Thanks for the info, Id seen a similar one but still doesn't make it that clear to me. There is a lot of clearance between the shock mount eye and the swingarm mount on my set up, probably have to get some sort of bushes don't like the idea of the washers in there. Trying to get some pictures of it uploaded.
Mind you after seeing how good that one in the link looks don't expect the same of this one
Old 26-Sep-2013, 23:26   #6
Read this:
http://www.ducatisportingclub.com/sh...ad.php?t=85276
Old 27-Sep-2013, 09:39   #7
Taking me ages to get these Fxxxxxg things uploaded ill do some more later, but you can get the idea of what Im trying to do. No where near finished.
can someone just point me to where I can see correct fuel pipe / pump connection to underside of 916 tank, want to run it with tank on. Thanks
Old 27-Sep-2013, 17:56   #8
749/916 Pumps usually have one of two types of hose connections, either a banjo bolt and steel pipe that the hose pushes on to or the quick release fuel couplings like these
http://www.ebay.co.uk/itm/MOTORCYCLE...em46002 2ffa0
748/916 pump unit is fitted with a 3-bar fuel pump and a matching 3-bar fuel pressure regulator to suit fuel injection
Old 27-Sep-2013, 21:04   #9
Skidlids
Does that mean this carb 2 valve won't run properly with this tank?
Trouble is I don't know how it ran before, I bought it in bits not running along with an M900 for the motor.
The outlets on the under side of the tank had 2 long pipes 13" long then a Y connector and another pipe approx 9" long to the carb rail way too much pipe under there. Also red and black connectors wired up to the pump?
I've had it running pouring fuel down the rail, starts very easily rear cylinder quiet, front sounds like I've dropped a spanner down plug hole. No smoke.
Any info on how to do this tank please, have to get it finished now.
Thanks for everyone's help
Old 27-Sep-2013, 21:31   #10
SS carby have a low pressure pump that switches with the ignition.
You should be able to swap out the high-pressure 3bar pump for an original SS one without too many problems.
There's been a few conversions on here in DD using 916 tanks, so someone should be able to help.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:21.
