Old 26-Dec-2005, 14:52   #1
phil996 phil996 is offline
Bikes: 888. multistrada 1200s sport
S4R No electrics-mystery
This is a mystery to me .I went out on Xmas eve for a quick 30 mile ride, came back washed and dryed off the bike with seat off and tank hinged up, since then no go, just a clicking from the two relays on the side of the battery. The only thing that works is the imobiliser light, no lights ignition or anything.
Any suggestions guys?
Old 26-Dec-2005, 15:04   #2
Dibble
Phil,
Down on the right hand side of the engine (as you sit on the bike) towards the front you will find the starter solenoid and a couple of connector blocks, these are notorious for vibrating loose and don't take kindly to being covered in water ... get in amongst them and disconnect, wipe off and reconnect them, this really only applies to the pop on pop off ones as they are usually the culprits, also check the fuses and the battery connections.
Hope that helps.
Old 26-Dec-2005, 16:13   #3
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
I had this on mine when i blew a few fuses after playing with rear indicators, whoops blew 2 was fine after replacing them
Old 26-Dec-2005, 23:17   #4
Sounds like it could be a relay knackered.Some Dukes are fitted with some real cheapo Siemens relays.Try swapping the two around that are near the battery to see what works.Had two fail on my wifes 900 Monster,now keep a couple of spares under the seat.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
