General Motorcycles only
Old 28-Dec-2005, 10:18
greenmachine greenmachine is offline
Mood: Flatulent
Which chain lube
Hi all, i've been using castrol chain wax for the last umpteen years but i hate the white mess it leaves and i'm considering a change back to a more 'conventional' lube - even if it means cleaning the back wheel and sprockets a bit more often.
Any suggestions? What about a scottoiler on a 996? all suggestions welcome. I even used to wipe engine oil on my chains with a cloth at first which was actually pretty good.
Cheers !
Old 28-Dec-2005, 10:59
adam adam is offline
Mood: happy
WD 40, cant get better.
Old 28-Dec-2005, 11:54
Dementor's Avatar
Agree with Adam WD40, some say it damages the O rings, but never experienced it myself. Cleans the chain, keeps the rust away, you get no build up and it's an excellent lube.
Old 28-Dec-2005, 12:04
3 in 1 oil, less than a quid from your local pikey shop.
Just keep the chain clean (I use WD40) and apply often.
Old 28-Dec-2005, 15:37
Wurth Dry Chain Lube, great stuff, hardley flings, very good.
Chris.
Old 28-Dec-2005, 17:21
Martinp's Avatar
Martinp Martinp is offline
Mood: 748ish
scottoiler all the way just leave and forget for 1000 miles the fill up!
Old 28-Dec-2005, 17:38
Carbon749's Avatar
Mood: I own a flame thrower
Cheers !
I've used Castrlol chain wax as well, the white build up is not the best sight but I do like the way it works and does not end up all over the bike.
Tend to wax the chain and leave the bike to stand for 24 hours, then spin the back wheel while it's on the stand and wipe off the excess wax.
Old 28-Dec-2005, 18:23
david.hicks's Avatar
david.hicks david.hicks is offline
I'd be interested as well. Does anyone have a Scottoiler on a 996? Pros? Cons?
  #9
Old 28-Dec-2005, 20:38
chris999 chris999 is offline
Mood: red and proud !!!!
just doesn't seem right !!
  #10
Old 29-Dec-2005, 16:13
clint 999R's Avatar
clint 999R clint 999R is offline
Mood: just love my slipper clutch
i use profi dry lube its the best chain lube i have ever used been using it for 5 years motorcross enduro trackdays and road you can get it from hein gericke you might have to order it tho £9.99 for a 380mm can
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:31.
