Old 28-Dec-2005, 13:11   #1
JasonBoswell JasonBoswell is offline
Bikes: 848
JasonBoswell's Avatar
Electrics gone kapput
Went to go for a short xmas eve ride but when I flicked the indicator and all the electrics blew on my 996. Luckily was outside the house, so not stranded, but bloody annoying
I'm sure this is 'must know' stuff, but whats the most likely causes of this??? The 3.5amp fuse for the indicators has blown, but even replacing this theres still nothing happening elsewhere - no dash, fuel pump, starter, etc.
Rather hoping this is something i can sort myself with a few choice hints from someone who knows more than i do!
Old 28-Dec-2005, 13:36   #2
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello Jason,
It could well be damp getting in where its not supposed too. Causing the short. I would check the big 30A charging fuse just in front of the battery, then the fuse up by the ECU I think its a 10A maybe different size on your bike. Check the battery with a multimeter, and there is no furring on any connectors then all fuses in the fuse box.
I am sure somebody will be alone with more knowlege with electrics, But thats where I would start.
Good luck hope you get it sorted.
regards
TopiToo
[Edited on 15-07-1968 by TopiToo]
Old 28-Dec-2005, 13:53   #3
weeksy2 weeksy2 is offline
i'm with Topi.... that sounds like a good place to start...
once you've confirmed all that check the connectors for headlight/indicators/clocks etc etc.
Old 28-Dec-2005, 17:00   #4
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
The indicator bullet connections that meet up with the main lume , tucked under the headlight unit can put too much "strain" on the current if the connections are dirty and may short across blowing the fuze ? 4D
Old 30-Dec-2005, 23:57   #5
Bikes: 848
checked all known fuses when it happended - except for one up by ECU (too late at night to do that now - where is it though so i can check in morning??)
Even if the bullet connections blow the fuse, i dont get why all the electrics have gone - unless just co-incidence with something more serious???
Old 31-Dec-2005, 00:12   #6
Bikes: 748ish . .
Hello Jason,
the fuse by the ECU in within a black casing, Lift the seat you should see it on the RHS. possibly a power surge, as the wiring on the orignal lumb is not that great, look for any signs of burnout wires working from the battery outwards.
regards
TopiToo
Old 31-Dec-2005, 01:27   #7
Bikes: 848
cheers steve - will have a look tomorrow. ive the option of the AA taking it to protiwns i guess.
hows things working out in the new house.... we should gather the great and the not-so of Twickenham for a beer one night?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:45.
