General Motorcycles only
Old 28-Dec-2005, 16:48   #1
Half man half mole Half man half mole is offline
Half man half mole's Avatar
Mood: Blue.....
LEDs
I am considering swapping the standard tail and indicator bulbs on my 748 SPS for LED equivilant. Has anyone already done this and, if so, were there any problems. Also, where did you get the LEDs from?I have seen a variety of styles and prices but I'm not sure which to go for.
Also, I have heard that there may be difficulties in regards to the LED indicators flashing too fast......?
Any advice apprecited.
Moley
Old 28-Dec-2005, 16:53   #2
tricky tricky is offline
Mood: Need spares
I've done the change over on a 749. So cant give you much info reguard 748 specifics but the indicator flashing to fast can be sorted with a load resistor. Most of the sites selling LED kits will mention these.
It just puts the extra load on the circuit that is usually associated with a bulbs filament, since LED's have a much lower power consumption.
Old 28-Dec-2005, 16:54   #3
phil_h phil_h is offline
phil_h's Avatar
The main prob with leds is that they are very directional ... and the bulb-sockets in the 748/916 tail point well up in the air ... so you will prob not pass an mot with them ... or be seen from behind as well as with std bulbs.
And yes, led indicators usually flash as if they have a failed bulb so need a modified flasher relay or whatever.
Old 28-Dec-2005, 18:04   #4
m1keyp m1keyp is offline
A mate fitted these to his 748R, they looked brilliant and he said easy to fit
http://cgi.ebay.co.uk/NEW-Ducati-LED...QQcmdZViewItem
Old 28-Dec-2005, 18:40   #5
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Nelly has a purpose made one which slots in nicely... as the led's are angled correctly the increase in light from the rear on the 747 / 916 is amazing... you can even see the tail lights in the day time.
I know BDG has one on his too.
Andy
Old 28-Dec-2005, 23:16   #6
Tinkler Tinkler is offline
Tinkler's Avatar
Mood: Horney
got one of the viper tech ones on my 748r looks good and works 100% better.
Well worth the money
hope this helps
Jamie
Old 29-Dec-2005, 10:51   #7
Washboard Washboard is offline
Of the 'replacement bulb' type LED's, the 19 LED variant has 19 rear facing LED's, while the 24 LED type has 18 rear facing and 6 radially mounted. I tried a 19 LED bulb in my 900ss, but found that as there was no reflected light, it wasn't really bright enough. With the 24 LED type, there is plenty of light hitting the reflector and the effect is similar to a standard bulb but with the advantages of LED's.
Old 29-Dec-2005, 18:56   #8
Mood: Blue.....
Thanks for the advice everyone.
Think I'm going to go down the route of a printed circuit board type rear set up and leave the indicators as they seem just too much hassle for the not-very-technically-minded mole.
Old 04-Jan-2006, 12:22   #9
Just fitted a couple of l.e.d bulbs in the 999 and the missus Monster.Went for the 24 l.e.d type,looks great.
Old 05-Jan-2006, 11:54   #10
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
I made my own for the ST4s Here's a pic
[Edited on 5-1-2006 by Derek]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:31.
