Old 30-Dec-2005, 18:26   #1
paynep's Avatar
Mood: Wet wet wet
Carb problem?
I've just been out fiddling with the 600ss before taking it down for a dyno session next week and while attempting to set the idle to something sensible came across the following:
I've balanced the carbs with vacuum gauges but the idle is really lumpy at 1200rpm. If I set the idle higher it is smoother, but when I blip the throttle the revs stick at 3500 until I switch off. Then when I start up again, its back to a lumpy 1200 rpm.
The carbs are exactly as I used them on the 675 last season, with a dyno jet kit with a 144 main jet.
Has anyone come across this, or do I have to strip down the airbox and carbs and investigate? Alternatively I could just leave it for the dyno........
Oh for the flatslides
Old 30-Dec-2005, 18:40   #2
Scooter916's Avatar
Mood: Hmmm Conference season
Paul sounds like an air leak to me.... Check all the manifolds etc.
glyn
Old 30-Dec-2005, 19:04   #3
FiscusFish's Avatar
Old 30-Dec-2005, 19:04   #4
phil_h phil_h is offline
phil_h's Avatar
Could be the air screws - remember the std setting is waaaay too lean, screw it out at least 3 turns more than std. (the std setting can sound as if its an air leak, its so lean)
And the o-ring on them can get damaged ... it can come off, but stay 'inside' when you take the screws out, and then get damaged and flap about a bit when you put the screws back in.
Old 30-Dec-2005, 19:11   #5
As Glyn says it maybe down to a air leak or possibly a dodgy diaphragm, Having never stripped my carbs I take it that the little housings on the side contain small diaphragms that control the coasting in-richners which could be sticking and causing a problem
Old 30-Dec-2005, 19:28   #6
butch890 butch890 is offline
Mood: Enjoying Togdom !
Neverhad any problems with our 620's!
Butch
Old 30-Dec-2005, 19:48   #7
paynep's Avatar
Mood: Wet wet wet
Cheers chaps, looks like I'll be stripping it all down to check out the suggestions
I knew that I shouldn't have just chucked the carbs in a box after Brands
Butch - I'm surprised that you know what a carburettor is - or did you borrow a history book from John?
Old 31-Dec-2005, 05:46   #8
[quote]Originally posted by paynep
Butch - I'm surprised that you know what a carburettor is - or did you borrow a history book from John? [/quote
Impertanant youngster!
Corse i know what one off them is,ive got 17 off them on the baby R (carbon and titainium -of course!)
Butch
Old 04-Jan-2006, 11:14   #9
paynep's Avatar
Mood: Wet wet wet
Well, I stripped everything down (again), put it all back together but wound the air screws out to 3 1/2 turns as per the 750 ss dynojet kit and things seem better, so good call Phil.
Carbs balanced again and dyno session booked.....watch out for the bhp shock!
Old 04-Jan-2006, 11:21   #10
phil_h's Avatar
Good news paul.
btw - where do you dyno
