Old 04-Jan-2006, 19:38   #1
YMFB YMFB is offline
YMFB's Avatar
Rear Discs
Today i had a new rear tyre fitted and the fitter pointed out too me that my brake disc is badly warped. I was very pleased with the service I got at Micheldever (hants) and would reccomend them, I believe it gets busy in the summer.
There is a corresponding mark on the wheel and looks as if something has been through the wheel and hit the disc. Surprising that I didnt notice it when it happened and even more surprising that the dealer didnt notice it at the last service, maybe the back wheel doesnt get checked
Anyway its warped and I need a new one, is there any reason why I shouldnt fit it myself, should I change the pads at the same time. Could anyone make a reccomendation on disc and pad manufacturers ?
Old 05-Jan-2006, 11:47   #2
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
If the disc is so badly warped that you can see it I'm surprised you haven't felt a vibration through the pedal.
It's no big deal to change it yourself. Once you've got the wheel out it is only held on by 4 allen screws but these will be loctited in. So make sure you have a good fitting key , preferably of the sort which fits your socket set wrench. It won't hurt to heat the heads gently with a small gas torch before you start. This breaks down the loctite.
When fitting the new disc make sure that the mating surfaces are perfectly clean so that the disc fits with no run-out. Remember to degrease the disc with petrol and always fit new pads with a new disc.
Old 06-Jan-2006, 23:58   #3
YMFB's Avatar
I dont suppose you know what torque setting the cap head screws holding the disc on should be.
Old 07-Jan-2006, 00:30   #4
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
I've replaced my rear disc with a Braking Wave one running Bendix pads....
If you need a rear one, I have my old one knocking about... you can have it for a small fee plus postage!
Brake disc bolts - M8 x 1.25mm - 25Nm +/- 10%
[Edited on 6-1-2006 by Rushjob]
Old 07-Jan-2006, 01:08   #5
YMFB's Avatar
Rushjob i ordered some a new set of EBC pads and disc, thanks for the offer and torque setting.
