Old 05-Jan-2006, 13:37   #1
CipiVTS CipiVTS is offline
CipiVTS's Avatar
cylinder head difference
Hi all,
Can somebody advise what is the difference between the top cylinder head of a biposto 748 2000 and a biposto 1995 916 ?
I want to buy the 916 one for my 748 engine
thanks and regards
Old 05-Jan-2006, 13:53   #2
Some of the 748's, mostly E models used the head designed for the S4 and ST4.
To fit those bikes the exhaust cam was lowered 20mm and uses a different cam belt to the "original" 748/916/996 types.
You can spot them by looking at the coveres than sit between the cams. The 916 will have 4 bolts holding it in place. The later type uses 5.
Check your 748 out and if theres 4 then you can use the 916, if there's 5 then you need to use the S4 ST4 type.
Old 05-Jan-2006, 19:21   #3
cjsperf cjsperf is offline
the 916 cylinder head holds allmost 10ccs more volume than the 748 so fitting one to a 748 will give much less compression and less power.
Originally posted by CipiVTS
Hi all,
thanks and regards
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:43.
