Old 10-Jan-2006, 11:19   #1
loverobot's Avatar
Removing chain -748s
What method are people using to get the chain off the above?
I have previously ground off the pins with a hand tool on other bikes but am thinking of buying a dremel?
Anyone used one to chop the pin end off?
[Edited on 10-1-2006 by loverobot]
Old 10-Jan-2006, 11:22   #2
Harv748 Harv748 is offline
Harv748's Avatar
I grind the pin ends off and then slide off the side plate.
I assume a dremel with the proper end tool on it will suffice?
Old 10-Jan-2006, 11:50   #3
loverobot's Avatar
what do you use to grind it off harv?
Old 10-Jan-2006, 11:52   #4
Angle Grinder of course!
Just grind the punched heads off the rivet link and remove it. You can then purchase another rivet link (I usually buy two when I order from B&C Express...) and put it back on again should you want to.
Old 10-Jan-2006, 12:08   #5
Harv748's Avatar
LOL...big 'feker 'n all!
Old 10-Jan-2006, 12:09   #6
Warning - use some kind of ear protection though! I was sorting out my trailer in the garage using the grinder and they didn't stop ringing for about 3 days afterwards!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:00.
