Old 12-Jan-2006, 11:23   #1
loverobot's Avatar
sprocket removal - 748
am i correct in thinking the sprocket (rear) can be removed with the wheel still on and that therefore it doesnt need raising on a stand?
i have acquired a renthal carrier and new final drive kit and want to do the swap
seems to me i just leave the bike upright and remove the spocket side nut, circlips, hub cover and spocket and then replace?
i am aware the nut will be tight - what size is it please?
many thanks
Old 12-Jan-2006, 12:43   #2
Harv748 Harv748 is offline
Harv748's Avatar
A) yes
b) yes
c) 41mm...it will be tight! I find that by poping around the corner to my local tyre fitting place with my correct sized socket, and asking then just to loosen it with their windy-gun helps in this regard! Then just nip it back up for the short ride home.
Old 12-Jan-2006, 12:57   #3
loverobot's Avatar
cheers again harv - i must try harder and try find a question you cannot answer lol!
if we ever do meet i certainly will stand you a beer or two!
