Old 14-Jan-2006, 23:52   #1
yorkie yorkie is offline
Bikes: 900 Monster, 750 SS Cafe Racer
yorkie's Avatar
Sprockets for SS
Sorry for probably repeating questions, but what size sprockets are fitted to a carbed 900ss. I have just got an engine for my Monster and i want it to retain the same spec as a SS.
What sprocket sets are used for speed? What sprocket sets are used for aceleration?
What stage jet kits are being used as well?
Cheers!!
Yorkie.
Old 15-Jan-2006, 00:23   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
It's probably 15 front as std as used on many Ducatis. You are probably better off putting a 14t front for everyday riding as it gives better acceleration and "mid-range". Personally, for the sake of chain life I'd leave the 15 on though and go up a few teeth on the rear. Small gearbox output sprockets really can bugger chain life.
Old 15-Jan-2006, 20:08   #3
yorkie's Avatar
But what about the rear sprocket and the jet kits?
What length chain would be a help as well!
Yorkie.
Old 15-Jan-2006, 20:23   #4
I can't help you with jets I'm afraid. Best speak to Baines for that. I am not sure if the SS and Monster airboxes are different. If they are different then the chances are that you will have to get the bike set up properly instead of just putting in the std jets.
Somebody here will know about the rear sprocket...try Iconic944 as he seems to be a font of wisdom when it comes to these bikes.
The length of chain depends upon sprockets being used - if I were you I would phone Rob Brewer at B&C Express just outside Lincoln. He'll be able to give a number of gearing and chain alternatives.
Old 15-Jan-2006, 21:03   #5
yorkie's Avatar
The air boxes and carbs are the same so i have not got a problem there!
Just jet sizes and rear sprocket!!
Yorkie.
Old 15-Jan-2006, 21:12   #6
Ian900SLV Ian900SLV is offline
Mood: All SP'ed up at the moment
carbed SS has 37 tooth rear sprocket as standard, but I have increased mine to a 39 tooth one for quicker acceleration and it also makes the bike feel less lumpy at low speeds in higher gears as it is revving just that little more, as for chain length I think its 98 links as standard
Ian
Old 17-Jan-2006, 01:09   #7
edwyun edwyun is offline
std was 15/37 but most switch to 13/39. some go to 40-42 for better acceleration but lower top end (but then you will prolly need a longer chain).
Old 17-Jan-2006, 01:17   #8
FiscusFish's Avatar
Originally posted by edwyun
...most switch to 13/39...
That's a typo isn't it...? Unless you've got a part time job pulling out tree stumps at the weekend..?
15/39 or 15/41 if you like acceleration more than 130 mph speeds.
Old 17-Jan-2006, 05:39   #9
sorry about that -
yup 15/39
Old 17-Jan-2006, 18:36   #10
yorkie's Avatar
SPEED
Speed is what im after! Thank you all for that!
Yorkie.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:45.
