General Motorcycles only
Old 14-Jan-2006, 22:55   #1
scuffy scuffy is offline
Mood: Ready for another V-twin
Ohlins forks ??
Anyone know if it is possible to get new lower fork/caliper mount brackets for Ohlins radial mount forks ?
Mine are cracked where some gorilla has over tightened the pinch bolts ( yes Nelly there is a gorilla bigger than me it appears :P )
I was going to replace the forks completely but the radial mounts are harder to come by and then some one suggested it may be possible to replace just the lower leg/mount .....
Old 14-Jan-2006, 23:27   #2
Carbon749's Avatar
Mood: I own a flame thrower
Do you already have radial mounts or are you taking the opportunity to swap standard mounts for radial mounts ?
Not sure of the extent of the damage, you could consider having it welded up and machined back again. Some one such as Spondon Eng' in Derby could do this properly.
Old 15-Jan-2006, 10:27   #3
Yeah they are already radial mounts
I'd still like to go down the road of replacement if its possible, but cheers for adding another option Carbon....I'd forgotten all about Spondon Eng.
Old 15-Jan-2006, 10:31   #4
Carbon749's Avatar
Only other option is an "after market" set of fork bottoms. You'll then need someone to swap them over unless you have the knowledge and tools.
Someone such as JHP or K-tec should be able to help.
As for your damaged ones either sell them as they are or have them repaired and then sell them. Will contirbute to the cost of your new set.
[Edited on 15-1-2006 by Carbon749]
Old 15-Jan-2006, 15:15   #5
Scuff'........... what's the mounting centers of the calipers? 100mm or 108mm?
I have a couple of possible "solutions"
Not that hard to swap over either. Coupleof hours once the forks are off. Give us a call or nip over
Old 15-Jan-2006, 20:51   #6
100mm centers dude......I'll give ya a bell later
Old 15-Jan-2006, 22:00   #7
ducv2 ducv2 is offline
Out of interest, how much are a set of ohlins radial mount fork bottoms and calipers worth?? And how do you get them off the fork legs without damage
Old 16-Jan-2006, 20:47   #8
Duke2BSteve Duke2BSteve is offline
Duke2BSteve's Avatar
Hi all, just to change the subject slightly, got a slight leak on both forks (ohlins), wot is a ball park figure for getting seals and oil changed. Also do the forks have to be checked and worked on by ohlin specialists???? any help much appreicated..
Old 16-Jan-2006, 21:05   #9
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
£75.00 by Ktec wth loose forks
Old 16-Jan-2006, 21:08   #10
Jon Jon is offline
Jon's Avatar
Scuffy these wouldn't be forks off another italan twin would t?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:33.
