Old 15-Jan-2006, 15:36   #1
duc daz duc daz is offline
duc daz's Avatar
brake fluid
im getting a slight leak of brake fluid from the reservoir on the handle bars ive tightend the srews a bit more so hopefuly that will do the trick (is this normal)
Old 15-Jan-2006, 15:39   #2
You need to make sure the seal under the cap is clean and seated correctly......
Old 15-Jan-2006, 22:21   #3
999TREV 999TREV is offline
999TREV's Avatar
Mood: Always red
Ive got the same problem with mine. Just cant seem to stop it, thats italian bikes for you, better than my bland rrw fireblade that just do's everything right all the time.
Old 16-Jan-2006, 14:46   #4
BigJohn999 BigJohn999 is offline
I had the same problem with my fluid reservoir covers. You need these anodised ally covers from http://www.carbon-trader.com/cnc-999.htm. Easy to fit (you use the existing rubber seal) and work well.
Old 16-Jan-2006, 21:36   #5
khu996 khu996 is offline
khu996's Avatar
My clutch cover is quite bad, although I have had it on and off numerous times.
The brake side looks as good as new though
Wonder if the anodized covers will hold up well over time...
[Edited on 16-1-2006 by khu996]
Old 16-Jan-2006, 22:09   #6
Loz Loz is offline
Loz's Avatar
Mmmm ... bling ... must ... resist .... aaarghhh
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:15.
