Old 16-Jan-2006, 09:48   #1
Maxypriest Maxypriest is offline
Mood: Fed up I'm not racing. :-(
600SS forks needed....
Ladies and Gents,
I've got fully adjustable on at the mo, and I know this is not allowed. What happened to the originals you may ask?... well after much searching in the shed, and noting that some other ‘shiny’ items are missing I can only deduce I’ve be robbed :-( ! And I hadn’t noticed!!!! :-o
Any one got any/know any for sale? Need twin disc ones really as I want to transfer current set-up straight over.
Cheers,
Max
PS 67 Days/ 9 ½ weeks to go…
Old 16-Jan-2006, 13:45   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I have a set of very good condition 750ss forks available. Would you be interested in these? Twin disk compatible as well.
I'd be interested in your forks as a swap plus some adjust your way. Can you confirm the dimensions required at the upper/lower yokes together with the overall length from the bottom of the fork to the top where the caps screw in. Also, what spacing are the caliper mounting bolts? Mine are 65mm.
Cheers!
Old 16-Jan-2006, 15:34   #3
Twpd,
Flip and blast.
I’m sure mine are the early 45mm versions fitted to carb’d SS’s. I believe that the 65mm ones are injection jobbies.
Old 16-Jan-2006, 18:33   #4
Measure them to be sure dude. I need another set of adjustable Showas for my other 800ss as spares.
I will measure mine tonight and tell you what they are.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:36.
