Old 16-Jan-2006, 18:45   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Fuel Filter
Has anyone found an alternative (maybe plastic) fuel filter from their local motor factors that'll do the submersible job?
I have a couple of X-refs of the Ducati part number, but my local factors don't seem to be able to make sense of them.
NAPA # 3032 to be exact. Also, the BMW K75, K100 fuel filter (# 13321461265).
The bottom line is it seems is that any 5/16 nipple fuel injection filter (aluminum can type) that's 2"--3" long (w/o nipples) and about 2" diameter will work just fine for our 4 valvers.
Old 16-Jan-2006, 19:02   #2
FiscusFish's Avatar
Fram G2 equivalent is listed here http://www.users.waitrose.com/~paso/parts.htm#Fuel
Doesn't mention the NAPA # but say's it's the same as the K series ones so...
Old 16-Jan-2006, 19:27   #3
weeveetwin's Avatar
Here's a few you might want to look at Rob;
BMW K100RS (as above) (or 16142325859)
AC GF61
Fram G2
Motorcraft FG-2
Old 16-Jan-2006, 20:16   #4
Rob B's Avatar
Thanks guys. That should to do it.
Rgds, Rob
Old 16-Jan-2006, 20:16   #5
Rob B's Avatar
Rgds, Rob
Old 16-Jan-2006, 22:05   #6
paynep's Avatar
Mood: Wet wet wet
The BMW one definitely works as I had to use one when Snells were out of stock of the DP one.
Old 20-Jan-2006, 10:50   #7
loony888 loony888 is offline
Mood: sensational!!
don't know if you guys get ryco but a Z200 works in mine. oh, and don't use a plastic one, they aren't designed to be submersed in petrol and can burst with 3.0 bar (or more) pressure.
Old 21-Jan-2006, 18:39   #8
Rob B's Avatar
Interesting, but my local motor factors produced a plastic filter when asked to cross reference that list. I have asked them to price the greman version that I had originally............
Rgds, Rob
Old 21-Jan-2006, 19:20   #9
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Scuse my ignorance but
1. Why not use a genuine part?
2. And should they be changed after a certain time , as mine hasn't been changed in at least 10 years?
I've obviously been riding round blissfully unaware it needed changing
Phil
Old 21-Jan-2006, 19:31   #10
Rob B's Avatar
I think it's an "every two years/5,000 miles" job. A new one is £13.50, and while not a huge amount, lots of peeps seem to think you can get them for a fiver or less. I thought I'd get one for the tank and another for the spares box.
