Old 18-Jan-2006, 12:17   #1
Chris Wood's Avatar
Hi Level exhausts - Brackets/fixings photos?
Good morning!
I have picked up some SL hi level cans, no brackets or fixings supplied.
Can some one post some pics or supply, or suggest the simplest fixings solution.
For my DD racer so no sexy options required.
Ta
Old 18-Jan-2006, 15:52   #2
Herb Herb is offline
Chris,
I have mailed you a photo of the bracket for the high level cans on my SS. Hope it helps.
The brackets on my bike with the straps for the cans were supplied by Ducati.
Old 18-Jan-2006, 16:00   #3
Chris Wood's Avatar
Cheers Herb.
Got the mail, will phone Ducati shops and speak to a fabricator....
Old 18-Jan-2006, 16:03   #4
No problem, let me know if you want me to measure anything.
I would have throught the parts should still be available as it is a common mod. Very easy to fabricate something though.
Old 18-Jan-2006, 16:09   #5
DaveDuc DaveDuc is offline
Mood: Sweet!!
Or you can get them here.........
http://www.ducati-kaemna.de/cms_en/k...el&artikel=390
Old 18-Jan-2006, 16:22   #6
paynep's Avatar
Mood: Wet wet wet
I have a pair of genuine Superlight ally brackets which have never been fitted.
Just add your bog-standard can fixing strap and you should be sorted.......
Old 18-Jan-2006, 23:37   #7
AL900SL AL900SL is offline
AL900SL's Avatar
Mood: Poor Grammer
It's a pritty crumby picture but these are the hangers on my SL with SIL Motot cans.
Hope it helps.
Allan R
Old 19-Jan-2006, 17:14   #8
Chris Wood's Avatar
Cheers All,
As soon as get the cans, will check if they have fixing holes or need straps?
Should'nt be difficult either way!
Old 19-Jan-2006, 19:38   #9
Zimbo Zimbo is offline
Zimbo's Avatar
Mood: fair to middling
Hey Allan R, do your Sil Motor cans sit fully home on the headers once mounted?? And do they have symmetrical curvy sections? I have a pair and first of all they are not symmetical: the curve on one is about an inch 'deeper' than the other, i.e. if you put the cans on the end of a table so the curvy bits both drop down vertically, the inlet of one is about an inch lower than the other. Shoddy. Also, the brackets are a bit long, so the pipes are barely inside the headers.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
