Old 18-Aug-2003, 21:48   #1
ShakMan ShakMan is offline
Mood: Its summertime!!
916 forks on a 748 ?
Hi,
Can someone tell me if 916 forks are same as ones used on a 748BP ?
Tks,
Shaks.
Old 18-Aug-2003, 23:31   #2
Dazza Dazza is offline
Mood: Rossi-tastico!
should be fine.
just make sure the 916 fork bottoms fit your type of caliper, the newer calipers are 65mm spacing, the old (916) are 40mm.
Old 19-Aug-2003, 00:07   #3
What do you mean by spacing ?
Can u explain in more detail please ... many thks!!
Old 19-Aug-2003, 00:31   #4
The distance between the mounting bolts changed from the original Brembo fitment of 40mm and used a M10 bolt with a 1.5mm thread pitch, to the later 65mm distance/spacing and changed to a bolt with a 1.25mm thread pitch but still a M10 (10mm diameter)bolt.
Old 19-Aug-2003, 20:29   #5
tks guys !!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
