Old 22-Jan-2006, 17:44   #1
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
Transponder
Just been out cleaning the bike and noticed my transponder in the tool box. I have none of the paperwork that came with it so I am unsure what to do. It has sat in the tool box since the last round at Cadwell. Should I keep it charged or flat? in order for it to work when we start again this season?
Mike
Old 22-Jan-2006, 17:50   #2
Mine is a rechargeable one that doesn't run off of the battery - if that makes sense. Its been run flat since Cadwell too.
Just charge it up a couple of days before the first round - it takes 12 hours or so for a full charge from flat.
Once its charged up and taken out it will work, putting it back in the charger-holder (without power) means that it's in sleep mode and so won't drain any battery power (or very little).
Tim
Old 22-Jan-2006, 17:57   #3
couchcommando's Avatar
Mood: ooooh
The instructions with mine say charge at least once a month.
Old 22-Jan-2006, 20:35   #4
multi600's Avatar
Mood: Hopefull
Thought as much I will stick it on charge in the morning. Cheers
Mike
Old 22-Jan-2006, 20:36   #5
tetol tetol is offline
Mood: ok
mine says every 3 months
Old 22-Jan-2006, 20:42   #6
Mine actually says to fully discharge every three months. Presumably this is to avoid "battery memory" - where the battery actually reduces its effective power range by only using part of its capabilities.
I reckon you'll be fine, you have in effect discharged the battery fully and are now recharging it. Albeit with a wait in between!!!!
Tim
Old 22-Jan-2006, 21:59   #7
domski's Avatar
Hrmm, interesting. Spookily I found my transponder today as well. I may just give it a blast in the charger, just to keep it warm during the winter
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:38.
