Old 23-Jan-2006, 18:55   #1
aka.eric aka.eric is offline
Fuel Hose
The fuel hose currently fitted (left in picture) is too big,outside diameter,jammed between frame and belt cover.
Local hydraulic/fuel hose supplier recommends hose(right in picture).My thinking was that fuel injection hose has a "weave" in the rubber,the one recommended is plain rubber with a cotton type overbraid,more like carb hose to my eyes.Any advice appreciated
Old 23-Jan-2006, 22:54   #2
RightSaidFred's Avatar
You want Goodrich stanless braided ones, you do
Old 24-Jan-2006, 14:26   #3
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
I think mine are like the one on the right.
I'll check tonight.
Can't you re - route it so it doesn't get trapped?
Phil
Old 24-Jan-2006, 18:11   #4
The problem is where the hoses pass between the frame and the cambelt cover.It was a pain to remove the tank as there was no movement in the hoses,would be impossible to remove the cambelt covers.
Hoses are not original,appear to be a bit too heavy duty.The recommended hose would be a perfect fit,but Im not convinced its "injection hose",last thing I need is a mobile barbeque!.
Old 25-Jan-2006, 17:00   #5
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
I also thought that injection hose always had the braid inside the rubber. Have you tried a car accessory place? They usually have lots of different sizes.
Keith
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:21.
