Old 23-Jan-2006, 21:22   #1
JonB JonB is offline
Do I use the Hammer on it ?
I'm just changing the stock pressure plate on my 999 for an adonised one. I have removed the pushrod from the original plate and noticed that it sits in a sort of collar that appears to be pressed into the middle of the bearing
Can anyone tell me how to remove this and transfer it to the new plate please, the hammer option seems a bit extreme
Old 23-Jan-2006, 21:36   #2
You ever regret starting something, and wishing that you'd left it alone.........
I guess that you know the feeling
Old 23-Jan-2006, 21:36   #3
duc daz duc daz is offline
duc daz's Avatar
put a over sized socket underneath and tap away easy
Old 23-Jan-2006, 21:39   #4
It is an easy press fit - a few small taps with a hammer (and socket) will free the sucker.
Old 23-Jan-2006, 21:41   #5
Thats the pressure plate release bearing. you can gently tap it out from out to in using a couple of sockets as has been said, then fit into the new plate. Oh dont forget the little cap that sits in the bearing.........that the rod sits in.
Make sure you put the push rod back in the correct way round!
[Edited on 23-1-2006 by andyb]
Old 23-Jan-2006, 21:49   #6
if it wont come out, stand on some step ladders and drop it on to a hard concrete floor (pushrod side down) that usually frees it up
Old 23-Jan-2006, 22:06   #7
Thanks everyone, opted fo the oversize socket and gentle tapping option over the more exciting and more expensive ladder/concrete combination and it freed it up
Old 23-Jan-2006, 22:19   #8
ericthered40's Avatar
Mood: renegade sexy racer
I was going to tell you about the shooting it out with a crossbow method but if your not prepared to drop it off the steps, any more interesting ways of removing it will be of no interest
Old 24-Jan-2006, 14:17   #9
veetwinducati veetwinducati is offline
Oh boy a broken hub pillar! Is it so common a thing for us to break? I foolishly tried to give a gentle tap to one of the spring screws to loosen it as the head would not hold the allen key too well! Doh big mistake! Ah well you live and learn!
Old 24-Jan-2006, 20:05   #10
Loz Loz is offline
Loz's Avatar
I used the first right-hander on the Rockingham circuit on my pillars. You can do more than one at once that way.
(Thought I'd say it before Andyb came charging in.)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:25.
