Old 23-Jan-2006, 22:31   #1
Murray Mint's Avatar
Powder Coating
How the feck do I get the sodding stuff off the frame, it was suggested to use a blow torch and a scrapper which has worked OK but I'm looking for a better solution.
Murray Mint
Old 23-Jan-2006, 22:34   #2
Bead or shot blasting is the way to go. It'll also give you a sound, clean base to repaint.
Old 23-Jan-2006, 22:34   #3
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
only bead blasting mate are you Re -powder coating?
Old 23-Jan-2006, 22:49   #4
The suggestion to use a blow torch and scrapper can from the guy thats going to do the repaint using a 2 pack paint, the idea behind his remarks are that the powder coat is quite soft and that the shoot blast just bounces of the paint, I have also heard this from another powder coating company
Murray mint
Old 23-Jan-2006, 22:59   #5
Bikes: 1098
madmav's Avatar
Mood: Chilled
Shot blast would be to heavy possible pitting of the frame!
Then it would need loads of PRIMER FILLER
BEAD blasting would be ok but it depends on the original powder coat
Chemical dip works well mate, and if you get it nickle plated b4 paint the finish is awsome
Old 23-Jan-2006, 23:02   #6
If you're going to "wet" paint the frame, than blasting will probably leave too rough a surface to get a smooth finish.
Shot, especially steel shot, won't bounce off the old powder. It'll clean it off no problems.
It's the wet coat you're going to use that's dictating a non abrasive stripping.
Have a look around locally for a chemical stripping company. There's too many nooks for the blow torch and scraper method. It'll take forever and you'll not get it perfect.
Old 23-Jan-2006, 23:28   #7
Bikes: 1098
madmav's Avatar
Mood: Chilled
nelly "Two" great minds eh
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
