Old 24-Jan-2006, 10:52   #1
851neil 851neil is offline
Mood: need a bike...
Help !!
Purchased a carbon tank a while back for my 851 and am having great difficulty finding a source for the 2 male and female connectors that exit each side of the tank...
Now I may have found a supplier but the problem is that I don't know what the thread size / specification is in the tank !!
Does anybody know this size & spec ??
cheers
Neil
Old 24-Jan-2006, 12:21   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Do you mean these? they are no longer available from Ducati
Old 24-Jan-2006, 12:23   #3
Rob B's Avatar
You also wanted to see these. These are on one of Phil's bikes (I think) mine are lent out at present.
Rgds, Rob
Old 24-Jan-2006, 13:28   #4
Rob, yes they are the connectors I need - Ducati no longer list em as available and they are like hens teeth.
I've found a pipe fittings supplier in Manchester who has a healthy online catalogue of parts and I thought that if I knew the thread size then I could order these up from him and at the very least make all on the forum aware of the catalogue number !
cheers
Neil
Old 28-Jan-2006, 15:15   #5
Rob B's Avatar
Neil,
Apologies for the delay, I have been forced to actually work for a living for the last few weeks!!!!
Anyway, I finally got around to measuring the threads - M20 x 1.5 looks like the job.
Good luck, and let us all know how you get along.
Rgds, Rob
Old 08-Feb-2006, 08:29   #6
jgriff jgriff is offline
jgriff's Avatar
If you have any luck finding a replacement for the tank connectors it would be good to know. I am seeing if I can get a set machined up. It looks like the bottom one in the picture has a check valve in it. Is that correct rob?
Old 08-Feb-2006, 12:17   #7
yup it has a check valve in it.
but there is a solution which I've discussed in the other thread...
cheers
Neil
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:09.
