Old 25-Jan-2006, 00:01   #1
gaz3014 gaz3014 is offline
gaz3014's Avatar
Mood: On the edge
Fuel Light
Fitted a JHP fuel cap the other day. Went to start the bike up, and after a couple of seconds, the fuel light came on, even with half a tank of fuel!!!
Any ideas??? Not sure if I kept the small breather pipe on the new set-up when I fit it.
Old 25-Jan-2006, 04:32   #2
http://ducatisportingclub.com/xmb/vi...=2415#pid18817
Old 25-Jan-2006, 07:14   #3
Did you disturb,or remove the tank when you fitted the new cap?
Could be the sensor is stuck.
Make sure you have all breather pipes connected,we would'nt want the pump trying to suck the tank inside out now,...would we?!
Old 25-Jan-2006, 10:48   #4
gaz3014's Avatar
Mood: On the edge
Didn't remove the tank!! Got a feeling the problem is with the pipe!!
Cheers for the help guys!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:30.
