Old 27-Jan-2006, 13:04   #1
migsangel migsangel is offline
migsangel's Avatar
Mood: Grumpy 'Old' Man!
Carb Heater Kit ?
Anyone know if this will work for on a 900...
http://cgi.ebay.co.uk/Ducati-600-Mon...QQcmdZViewItem
Old 27-Jan-2006, 13:10   #2
Good price...
Seem to remember either Nelly or Skidlids answering a question along the same lines - I tend to think it might but - you'd need to make sure I think - phone Nelly @ cornerspeed - dont think he'd mind, just buy some oil off him while your on the phone
There is a new guy here with 600ss that sounds like he's having icing problems as well - and not on his cake !!!
F
Old 27-Jan-2006, 13:12   #3
Dave G Dave G is offline
Dave G's Avatar
Hasn't your 900 already got a carb heater line?
I'm sure these are standard across the range though,as long as your carbs have the bolt holes to attach them to.
Old 27-Jan-2006, 13:21   #4
My 93 900ss - has not got got the carb heaters line - but there again I wasnt the first owner by a long way...must check up in the 'bible' to see when these started to be fitted....
Just checked...according to Falloon, before 1997 the carb kit was only an option - fitted as std to the 1997 range and beyond....
F
Old 27-Jan-2006, 13:38   #5
bolds bolds is offline
wont fit 900ss as that kit is for bike without oil cooler
Old 27-Jan-2006, 14:08   #6
Good point - forgot that completely - but, if it sells for the auction price of £20 it sounds well cheap....could it be made to work???
If the take-off points are the same - wouldnt it just be a case of fitting double cable banjo bolts - or is there more to it than that?
F
Old 28-Jan-2006, 15:01   #7
migsangel's Avatar
thank you eveyrone for your input...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:40.
