Old 29-Jan-2006, 21:51   #1
Carbon749's Avatar
Mood: I own a flame thrower
What is the thread size - 749r tank breather plug
Would anyone know what thread size the breather bung on the 749r tank is ? and does anyone where to buy a cheap fitting for this to set up the race style breather.
The DP fitting and breather pipe with one way valve is over £110
Like the look, but, not prepaired to pay over a £100 for it.
[Edited on 29-1-2006 by Carbon749]
Old 29-Jan-2006, 22:16   #2
khu996 khu996 is offline
khu996's Avatar
Whats the benefit of the breather style set up?
Old 29-Jan-2006, 22:22   #3
Carbon749's Avatar
[i]
Pure bling value ... make the bike look different to all the other 749r.
Old 29-Jan-2006, 22:52   #4
khu996's Avatar
Cool. As good a reason as any other!
How are you going to make it work? Are there any pics of the breather set up on race bikes?
Old 29-Jan-2006, 22:56   #5
Carbon749's Avatar
According to JHP .... Fit the hose tail to the tank, length of pipe and valve. If you want to go the full mod, loop the existing breathers that come out of the tank near the ignition so that the two pipes that exit are connected together and then use a small blob of silicone in the breather hole under the fuel cap.
You can just fit the race style breather and leave the standard vent set up as well.
Old 29-Jan-2006, 22:57   #6
khu996's Avatar
Sounds good.
If you're gonna do it, post some pictures when you're done.
Old 29-Jan-2006, 23:18   #7
I have a feeling it'll be either 10mm fine or 3/8"bsp...............????
Only a hunch though. Definately check/measure before hand
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:12.
