Old 30-Jan-2006, 15:46   #1
ricco749s ricco749s is offline
ricco749s's Avatar
Mood: don't do moody
999r HEADLIGHT SWITCH?
Just acquired an '04 999r with the Volvo-like headlight arrangement, with headlight on/off switch blanked off & dipped beam permanantly on (other than when starting). Would appreciate advice on whether its possible and straightforward to replace the switch for a standard 749/999 on/off without having to modify the wiring? ie does the necessary wiring run into the existing switch but is simply not connected/utilised? Want to be a little kinder to the battery...thanks.
Old 30-Jan-2006, 15:56   #2
itexuk itexuk is offline
itexuk's Avatar
Mood: Great
I think all 749 / 999 have same switch as yours, my 749S is the same, dip on all the time. If ignition is on but motor not running it turns itself off after a short time to save the battery.
Old 30-Jan-2006, 16:03   #3
ricco749s's Avatar
Thanks..my '03 749s has an on/off switch and I know that the only previous owner didn't modify it, so maybe all post '03 749/999's have the same silly arrangement?? I personally like to have the power (sorry) of choice over the headlight being on...
Old 30-Jan-2006, 16:17   #4
khu996 khu996 is offline
khu996's Avatar
My 03 749 bip had a normal on/off switch.
Seems that a lot of manufacturers are going for the safe Swedish approach to headlights
I'd like to change mine too!
Old 30-Jan-2006, 16:20   #5
ak47 ak47 is offline
Bikes: KTM Arsey Ocho
ak47's Avatar
Mood: retiring
I think that it is law that all new bikes have to have the light on all the time.
Old 30-Jan-2006, 16:26   #6
That's my understanding too, a year or two ago all bikes are required to have the light's on all of the time
Old 30-Jan-2006, 18:05   #7
khu996's Avatar
The law can crawl back up its own ass! I want to be able to control whether the lights are on or not!
Would it be a matter of simply fitting the older switch?
Old 30-Jan-2006, 18:50   #8
Ducnow Ducnow is offline
Strange..... my 04 R has the switch.
Does your's have it to JPM?
Old 30-Jan-2006, 18:54   #9
Now you're asking a question I just can't answer, mine never ran on the road with lights on, first thing I did was whip the headlight assembly off and fit a trackday kit
Old 30-Jan-2006, 18:55   #10
Carbon749's Avatar
Mood: I own a flame thrower
my 03 749s has the switch my 04 749r has no switch. I'd also like to take control back.
I have a track day fairing with no headlight cut outs. If I leave the headlight switched on it will melt the track day fairing. Would rather be able to switch it off, if not looks like wires off the back of the low beam when I fit the track day set up
[Edited on 30-1-2006 by Carbon749]
