Old 30-Jan-2006, 16:08   #1
weeksy2 weeksy2 is offline
Getting an engine out.... (and obviously back in)
Well just sort of wondering on this one really.
Debating on how easy/hard it is to get the engine out of a 916.
Reason, my back of engine is scruffy and could do with rubbing down and painting.
So how much work is involved and where exactly would one start ?
Old 30-Jan-2006, 16:20   #2
Not that hard Steve. Body work, air box etc. off.
Injectors and cooling system out of the way. Exhausts off.
Get all the wires and cables out of the way then three bolts and your there
A bit simplistic, but you get the picture
The only usual problem is the swingarm pivot. If it's seized, then you may need another 4 hours.............. if you're lucky.
Refitting is, as they say, a reversal of the above. Get a Haynes, a helping pair of hands and your tool kit and you'll be off!!
Old 30-Jan-2006, 16:26   #3
Cheers mate, was just chatting to big Al as well while you were writing this
Sounds simple enough really. pretty much a weekend task for me and one of the boys.
Will see you on Sat and have a quick peek where the engine mount bolts are located and chat about the 'paint' type side of things.
Thanks fella.
Old 30-Jan-2006, 16:34   #4
Harv748 Harv748 is offline
Harv748's Avatar
Look here...you won't be the first this year!
http://www.ducatisportingclub.com/xm....php?tid=25880
As Nelly says...the real sod is the swingarm bolt...I guess its possible to test if its gonna budge before you start? Save you stripping the bike down, only to get stuck with the bolt and having to put it all back together again a beaten man!??
Mine wouldn't, so I left the engine in the frame and just removed everything else!
Old 30-Jan-2006, 16:41   #5
keefer keefer is offline
keefer's Avatar
I guarantee your swing arm bolt will be stuck.
otherwise a quick job. good luck
Old 30-Jan-2006, 16:51   #6
Tell me more about the Swingarm bolt then guys ?
i'm working in London so can't shoot down and have a peek at Ceris bike.
the other option is to do in situ but not sure i'll be able to get enough of the engine in the confined spaces.
Old 30-Jan-2006, 16:57   #7
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Mine came out rear easy, some people had problems with it sticking half way.
You could always try and remove the swing arm bolt first to see if it will move easily or not, and if it doesn't move DON'T strip your bike
Old 30-Jan-2006, 16:59   #8
Harv748's Avatar
See above thread...all explained in graphic detail !
Basicaly it can seize itself in there and can take HOURS to remove...even by the pro's.
Its pot luck basically...some can almost be pushed out by hand (well, not quite) whilst others get out so far, then no more, and need drilling/cutting out...not a nice job.
Old 30-Jan-2006, 17:05   #9
keefer's Avatar
sorry you may be ok.
its all down to how much bad weather they have seen.
those that don't know rain exists are generally ok
Old 30-Jan-2006, 17:06   #10
Dave the previous owner was not scared of a bit of rain...
soapy water... that's a different matter hey Dave
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
