Old 31-Jan-2006, 10:03   #1
frazelli frazelli is offline
Mood: whatever!
Help and advice please - Rear axle issue
Chaps,
I am currently rebuilding my 748 following it's winter stripdown and have found a problem with the rear axle.
Basically it will only fit into the eccentric hub if I knock it in with a pretty hefty hammer. I can't remember now when I removed it but should it not just slide in freely by hand?
Also once it is in it will barely turn!!
Can any one offer some advice please? Could it be the bearings?
I am at a loss as it is the original part that I took out which was fine!?
Regrads Frazelli
Old 31-Jan-2006, 10:14   #2
Carbon749's Avatar
Mood: I own a flame thrower
From a recent experience the hub does need a gentle tap to knock it in and out .... maybe daft, but, make sure the pinch bolts are completly loose on the back of the swing arm.
As for it turning I had to use the C spanner, it will not turn without it.
Old 31-Jan-2006, 10:50   #3
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
My axel slid into my hub no problems without having to hit it!
Would it be possible for you to take some pics on how you are trying to fit it (seems like a stupid request but we might see something you have missed).
I take it the hub has been fitted the right way round (daft again, I know)
Old 31-Jan-2006, 10:52   #4
dave996's Avatar
Mood: Fed up...
If you have done up the pinch bolts to tightly you could have cruched the bearings!!!
Old 31-Jan-2006, 14:14   #5
Mood: whatever!
Thanks Dave
I'll have a look at that as everything was ok before! I did wonder if it may be worth replacing the bearings?
Regards Frazelli
Old 05-Feb-2006, 20:33   #6
yorkshire pud yorkshire pud is offline
Mood: poon tang
comes as a a unit. but you can change bearings.
Old 05-Feb-2006, 20:41   #7
tetol tetol is offline
Mood: ok
have you had the swing arm refinished build up of powder coat or paint?
Old 05-Feb-2006, 20:59   #8
Sounds like one of the rollers in the bearing got dislodged. Hitting it could've damaged the bearing cage.
Old 06-Feb-2006, 15:17   #9
Mood: whatever!
Thanks for the input chaps,
Ended up replacing the whole unit which has solved the problem!!!
Regards Frazelli
Old 06-Feb-2006, 19:10   #10
yeti yeti is offline
yeti's Avatar
Took the words right out of my mouth
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:20.
