Old 01-Feb-2006, 10:47   #1
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
Steering damper turning/acceleration?
Got an ohlins steering damper on a 749 2003 and when you turn to full lock on either side it makes the bike accelerate which obviously is very dangerous, has anyone come across this if any answers are welcome.....
cheers mark
Old 01-Feb-2006, 10:52   #2
dickieducati's Avatar
there is absolutely no way a steering damper wll make your bike accelerate. probably your idle lever.
Old 01-Feb-2006, 10:58   #3
i would say its the routing of either your cold starty cablr, or more likely throttle cables................
Do your self a favour and upgrade to a 998 throttle assembly, changing to a single cable. This will also eliminate 30 odd degrees of rotation to open the throttle fully!
Old 01-Feb-2006, 11:58   #4
gimpboy450's Avatar
I shall investigate the problem and see what happens. cheers
Old 01-Feb-2006, 12:25   #5
Mood: Diet
i had something similar, i thought that it was the throttle cable , but it turned out to be the fast idle cable was routed the wrong side of the clutch line, once i moved it the problem was cured
