Old 01-Nov-2013, 16:27   #1
kiwicoops kiwicoops is offline
Bikes: M620ie, DD583R #30
kiwicoops's Avatar
Why we don't use fibreglass tanks..boom
gas cloud slowmo replay footage at the end of this clip.
http://www.youtube.com/watch?v=ZJkA-_OCQVQ
pete
"Nearly all men can stand adversity, but if you want to test a man's character, give him power". Abraham Lincoln ...53 horse power should do it
Old 01-Nov-2013, 19:53   #2
I thought Vince's Barbequing of Nori at Oulton was a good enough demonstration
But that clip shows one hell of a race track
Old 10-Nov-2013, 11:54   #3
Fruitbat Fruitbat is offline
Bikes: Hypermotard, 600ss
Fruitbat's Avatar
Mood: Positively pensive
Alunium/fibreglass/steel/carbonfibre?
Didn't realise that they raced at Greymouth as well - seemed such a peaceful place when we passed thru in 2006. Those nasty noisy motorbikes...
Alloy gotta be better than fibreglass but I'm not sure anything would've survived that - full weight of the flipped bike as it returned from orbit, closely followed by a direct hit at speed by the following bike.
Steel/alloy would deform before rupturing - but what happens to carbonfibre tanks when subjected to forces that they can't cope with?
Old 10-Nov-2013, 17:51   #4
same, that's why we're not allowed them.
Old 10-Nov-2013, 20:14   #5
Hence my reference to Vince's crash in front of Haga at Oulton
http://www.youtube.com/watch?v=LeKATCZvweE
Old 11-Nov-2013, 08:44   #6
Fruitbat's Avatar
Sorry, should have phrased the question more carefully...
Interested in exactly how CF fails - can it deform at all or does it simply splinter / rupture? Carbon/Kevlar mix any different?
Old 11-Nov-2013, 08:46   #7
Fruitbat's Avatar
Interested in exactly how CF fails - can it deform at all or does it simply splinter / rupture? Carbon/Kevlar mix any different? Just curious
Oulton clip makes interesting viewing...
Old 11-Nov-2013, 20:12   #8
i'm pretty sure it just breaks, the same as fiberglass, formula 1 use a soft carbon fiber and Kevlar reinforced rubbery material which bends and flexes
Old 12-Nov-2013, 00:21   #9
Your probably right there Matt,
I suspect Autoclaved Prepreg CF will take more abuse than wet lay-up fiberglass , but a hard enough smack at the right angle will no doubt crack it open. Adding Kevlar probably moves this point up the curve a bit.
I think its under the FIM rules that if you run a CF tank you need a FIM approved internal fuel cell that costs more than the tank.
Old 12-Nov-2013, 15:02   #10
I also remember reading somewhere that the large capacity endurance tanks have to be filled with some sort of sponge filling which prevents fuel from running out even if the tank is split.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:38.
