Old 06-Feb-2006, 05:39   #1
StashTheGumbo StashTheGumbo is offline
Clutch Drum Nut
I'm using so much force it feels like something has got to break soon. Yes I'm using the right tools and have tons of leverage.
Is this nut revers threaded?? I can't find any docs saying so, but have to ask.
This mother fletcher is frozen!!
Thanks in advance,
Brian
Old 06-Feb-2006, 09:34   #2
Get down to Halfords and spend £12.99 on a 12 volt impact wrench. That'll sort it.
Old 06-Feb-2006, 09:40   #3
Ah, i see you are in the US so you might not have Halfords!!
Old 06-Feb-2006, 13:20   #4
Totto Totto is offline
I think that nut is on with 186Nm (corrected) so it will be tight
The Impact wrench would be a good idea if you can access to one !
[Edited on 6-2-2006 by Totto]
Old 06-Feb-2006, 14:47   #5
I've already tried using my air impact wrench set at about 110 lbs (just about the wrench's maximum). All that did was bruise the nut.
I've got a quality clutch holding tool braced under the slider. Then with a long socket wrench pointed upwards I'm pulling while anchoring myself with the rear subframe.
I think I'm screwed (no pun intended).
Old 06-Feb-2006, 15:02   #6
748mart 748mart is offline
How long is the bar you are using? the one I use is about 30 inches, needs to be at least about 24 inches. Don't worry it's not a reverse thread.
Old 06-Feb-2006, 15:06   #7
mikesps mikesps is offline
The manual says 186 Nm, which is about 137 ft lb. You are almost there!
Old 06-Feb-2006, 15:30   #8
OK thanks all. I'll give it another go this evening. If something goes snap, oh well. It's taking a lot more force than the rear wheel nut (which I've taken care of on regular occasion) which I thought is funky so I had to post my above question.
Old 06-Feb-2006, 18:35   #9
m1keyp m1keyp is offline
I had to use a 3 foot long scaffold pole
Old 06-Feb-2006, 18:41   #10
stephen hall's Avatar
tight nuts
my nut was very tight 1st attempt fu*ed the basket so new one needed, but with a helping hand and the proper tool all be it made up myself, my nuts come off now na probs!
