Old 08-Feb-2006, 15:56   #1
loverobot's Avatar
coolant
for my trackbike should i be using standard coolant or water wetter? do circuits specify?
Old 08-Feb-2006, 16:06   #2
dickieducati's Avatar
use what you like. dont think circuits sprecify anything special for trackdays.
Old 08-Feb-2006, 16:07   #3
loverobot's Avatar
excellent
coolant it is then
will be finished tonight
Old 08-Feb-2006, 16:09   #4
yeti yeti is offline
yeti's Avatar
Circuits HATE coolant, it can't be cleaned up like oil and I believe it's banned on some tracks on the continent - and they check. I'm going to be using distilled water in the beast.
Old 08-Feb-2006, 16:11   #5
loverobot's Avatar
not so excellent then yeti!
are you using a rust inhibitor and where do you get distilled water from?
Old 08-Feb-2006, 16:13   #6
yeti's Avatar
Yes at the moment it does have rust inhibiting coolantm and I'm getting the distilled water out of my dehumidifier. It's about as pure as you can get. Failing that most garages/battery shops will sell you some for two thirds of f**k all.
Old 08-Feb-2006, 16:14   #7
yeti's Avatar
Notwithstanding all of the above, I have never heard of any UK circuit checking on a track day.
Old 08-Feb-2006, 16:16   #8
loverobot's Avatar
is that for a dd bike yeti?
Old 08-Feb-2006, 16:18   #9
Not aware of any trackdays stipulating water only, but......... If you are going to run water only, distilled or otherwise, drain and flush the system regularly.
It doesn't take long to start clogging the cooling system up, especially the rad.
The corrosion also eats away at the mechanical seal behind the pump impeller and then you'll be running water/oil in your cooling system
Old 08-Feb-2006, 16:18   #10
loverobot's Avatar
btw dickie - booked the 18th at cadders - never been there - would be good to meet and get some advice re lines / etc
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:26.
