Old 09-Feb-2006, 15:23   #1
aka.eric aka.eric is offline
Fairing Air Intakes
Should there be any mesh in the nose cone air intakes,not shown on parts catalogue.Some seem to have it fitted,Nattyboy is it needed ?.
Old 09-Feb-2006, 17:11   #2
weeveetwin's Avatar
It's not original fitment eric. Don't have it on mine.
Old 09-Feb-2006, 20:22   #3
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
No, because the air tubes flow air in above the filter. The filter catches the bugs, birds and small children.
Rgds, Rob
Old 09-Feb-2006, 22:54   #4
851neil 851neil is offline
Mood: need a bike...
is anybody running the carbon corsa airtubes plus the carbon airbox ?? if so what was your filter solution - I need to steal some ideas !!
cheers
Neil
Old 10-Feb-2006, 03:51   #5
jgriff jgriff is offline
jgriff's Avatar
Are you talking about the 3 piece shroud assembly that has no place for a filter to fit. My answer is K&N. Standard tube type with 62mm hole. Then make up a set of collets (outside dia 61-62mm) for each Velocity stack out of nylon. Remember top make sure they are tapered. Problemo solved.
Old 10-Feb-2006, 04:09   #6
jgriff's Avatar
Neil, I'm getting the tank connectors machined up if they are any good you interested? Cost is not going to be cheap. I searched to country to no avail.
Old 10-Feb-2006, 06:38   #7
loony888 loony888 is offline
Mood: sensational!!
i'm not sure the corsa carbon air tubes will fit a road bike, the yoke offset and width don't leave enough room.
Old 10-Feb-2006, 09:36   #8
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
No mesh as standard, but I added some gold mesh to to mine just for aesthetical reasons as I think it just finishes it off nicely
If you zoom in on the attached pic you can just about see what it looks like..
Nat
Old 10-Feb-2006, 10:40   #9
loony, I've trial fitted them to the bike and they fit up a treat, this is with Harris yokes though (wider) + larger diameter Ohlins road and track forks.
No problem lock to lock.
jgriff, if you could u2u me with some costs for these - are you talking about a reducer that would allow fitup of the smaller diameter inserts or are these going to be replicas of the original parts ??
cheers
Neil
Old 10-Feb-2006, 12:13   #10
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Have a look Item nbr 25 ...
... and on the following, how the original Coras looks like ...
Phil911
