Old 09-Feb-2006, 19:56   #1
Rick Rick is offline
Drive Packet
I shall be buying a new Drive packet ie
New REAR sprocket
Sprocket carrier
Chain
front sprocket
After reading the post about the chains snapping , what are the best recomendations on what to buy .
I am after a RENTHAL carrier and Rear sprocket , any other suggestions ??
Old 09-Feb-2006, 19:57   #2
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Look at Talon.
Old 09-Feb-2006, 20:46   #3
Gaz 748's Avatar
Talon are very good.
Old 09-Feb-2006, 21:25   #4
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
For the chain, our Nelly reccomends Tsubaki.
Are you after a quick change rear sprocket? I have the Talon stuff and changing the back sprocket is really quick and easy, like it says in the tin really! Only really neccessary if you change you ratio frequently, but also with the Talon carrier (don't know if it's the same for others) is that it captivates the cush drives so they don't shift out and grind themselves away on the swing arm - not a common problem, but it's not unheard of.
For a QR carrier, make sure there's not a shortage of theadlock... you wouldn't want the sprocket retaining bolts falling out on the M27, hypothetically speaking !!!
