Old 12-Feb-2006, 19:21   #1
greenmachine greenmachine is offline
Mood: Flatulent
Open clutch covers
I was wondering - what precautions or other 'expenses' should i factor in when changing to a vented cover? Do i need stainless bits'n'bobs (eg springs) fancy friction plates etc? or is it really as simple as swapping covers. I'm just thinking of the open-to-elements internals and don't want to cause excess wear and tear.
I must also say how good this site is after several months perusing. A proper enthusiasts site and a fountain of knowledge. Not many like it on the 'net i can tell you
Cheers,
Russell.
Old 12-Feb-2006, 19:29   #2
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
just swap the covers job done stainless springs coloured pressure plates etc pointless bling nice bling none the less
Old 12-Feb-2006, 19:33   #3
Dibble
It'll be fine, just swop covers, the only thing is the orginal pressure plate is an ugly thing .... and the original bolts, top hats and springs just go furry and look awful, still all works ok though ...
Or spend some real money and do this ....
Old 12-Feb-2006, 19:35   #4
Your only concern might be what happens if the bike goes down on the right hand side....
Old 12-Feb-2006, 19:36   #5
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Cheers,
Russell.
Changing the cover is really easy, just take the standard one off, out the new one on.
Some Ducatis come with a rubber type gasket that sits behine the clutch cover, if yours has got this you may need to keep it on if you are using an after market clutch pressure plate as these can vary in overall thickness.
Or you could space the cover out with a few thin alloy spaces/washers. Only really a problem if the after market pressure plate hits the open clutch cover when being used.
You can add new stainless clutch springs and caps but this is pure bling and to stop any rust if these bits get wet.
DC.
Old 12-Feb-2006, 19:36   #6
DC DC is offline
DC's Avatar
Nice clutch cover Dibble..................................
Old 12-Feb-2006, 19:38   #7
DC DC is offline
DC's Avatar
Too true.
Some after market pressure plates are deeper where the springs are situated, so possibly protecting these in an off on the clutch side.
Old 12-Feb-2006, 20:19   #8
Stealth Stealth is offline
Bikes: 998R, Panigale S
Stealth's Avatar
definitely put spacers in or you can find springs will extend and hit outer cover (this becomes more the case as springs age - expect huge technical view on whether or not this really happens - but it has been known.
Also, don't use stainless springs if you have any from of race clutch lightweight, slipper or four post. They just ain't up to it.
Old 12-Feb-2006, 20:19   #9
Stealth's Avatar
Old 12-Feb-2006, 20:19   #10
Stealth's Avatar
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:13.
