Old 13-Feb-2006, 12:07   #1
andya andya is offline
andya's Avatar
Bearings
Hi
Has anyone got any good/cheap suppliers for wheel bearings and head bearings?
Also the rear hoop rose joints too.
Andy
Old 13-Feb-2006, 13:02   #2
jgriff jgriff is offline
jgriff's Avatar
I just go to the local SKF or Timkin dealer with said bearing or rose joints. They are not specialist parts unless you have a 1989-90 851. Then rose joints become rude.
Old 13-Feb-2006, 13:07   #3
851neil 851neil is offline
Mood: need a bike...
totally agree with that - take examples to your local Bearing Traders and they'll sort you out at a fraction of the Ducati OE pricing.
Old 13-Feb-2006, 17:05   #4
Most bearings have a number on them (probably on the outer race) which is a standard generic number. Quote that number to a bearing factor and they'll be able to provide a suitable bearing regardless of manufacturer.
Try and go fo a quality make like SKF though, I got some nameless rear wheel bearings that were probably made in the far east somewhere, looked OK, fitted OK and lasted 3 months
Old 14-Feb-2006, 16:35   #5
andya's Avatar
Tried my local supplier - he reckons the bearing was dicontinued in 1993 and no bearing manufacturers still make them.....................!!!
Has anyone got any from anywhere recently ???
Old 14-Feb-2006, 17:25   #6
Charlie Charlie is offline
Bikes: T8 SP4 / Buell 1125CR
Charlie's Avatar
Worth a try.. ~ http://www.midlandbearings.com/
Old 14-Feb-2006, 17:41   #7
Bearing Traders in Bishop Auckland, got my new head bearings there.
The Wheel bearings ring a bell - checked my little book and what I had to do was buy Ducati stuff, essentially there's a new inner spacer to go with the bearings for the front wheel + 2 metallic spacers and if I remember correctly the rear wheel takes 4 bearings (2 in the cush) and again with a new central spacer piece. Once you have the Duc OE stuff replacement afterward is the cheaper bearing trader route.
cheers
Neil
Old 14-Feb-2006, 19:44   #8
andya's Avatar
Thanks guys, tried a couple more bearing traders in my area and they still are available. The people I tried first are obviously just crap or couldnt be bothered...takes all sorts...
anyway they are on the way by post, ideal.
