Old 14-Feb-2006, 18:59   #1
Griff 64 Griff 64 is offline
Griff 64's Avatar
Mood: 1st,start to finish
Questions,questions questions?
Okay,if the website can stay working long enough can anyone help with advice on the following.
1.Gearing. Need new chain and sprockets.Suggestions please regarding standard front and how many rears,stick with standard, change it every round etc.
2.Braided brake lines. Anyone got a good deal anywhere.
3 Tyres. Pirelli Diablo but what speed rating is required by the regs.Beleive the choice is noted by R17 or ZR17 for over 130 mph.My bike will do this i,m sure[ especially if it does not lie down and give in to being built nicely ]when i send it off the nearest cliff
4 Oil catch trays. Where do the available trays fix to on the engine / fairing.Does anyone have any pics.
Right, thanks alot i,m off to hit the bike with my fcuk off big hammer now to show it who,s boss
Old 14-Feb-2006, 19:06   #2
ali ali is offline
ali's Avatar
Mood: Damp
I ran a 14 for most rounds last year, and made do with 3 rears, a 41, 43 and 44. (1996 600SS)
Sorry, can't help. Fleabay usually.
As long as they've got Diablo on the side (and no Corsa markings....) then buy 'em.
The SS bellypan I had fixed to the fairing using the wellnuts.
Good luck,
Ali
Old 14-Feb-2006, 19:18   #3
domski's Avatar
When was that rule brought in?
Old 14-Feb-2006, 20:18   #4
DSC Member AK AK is offline
AK's Avatar
Dom, I thought you pencilled that one out!
Griff, cant advise on gearing unless we know what bike you have/engine too.
There is different primary drive ratios for the 583, depending on whether pre 98 or post 98.
For 583 monster (2000) we run most of the time on 14/45.
Brake lines? - wot Ali said, but why are you changing them? - and dont forget the front ones have to split above the bottom yoke. (dont get 916 ones, as the wont pass scrut, as they split below the bottom yoke)
Old 14-Feb-2006, 20:24   #5
Griff 64's Avatar
HI Ak and Ck
Bike is a 95 600ss running in 583.
Changing the brake lines as they are the original rubber ones and i thought they needed to be braided.Going to try single disc brake to start with at least.
My exhaust system cut up a treat thanks .I will try and post a picture soon.
Old 14-Feb-2006, 20:39   #6
phil_h phil_h is offline
phil_h's Avatar
After skids posted his gearing chart I did a bit of work to simplify mine and merge it with his ... see if this makes any sense, and let me know if it helps ...
pchweb.co.uk/desmodue/duc gearing (skids).xls
If it works, and anyone wants to contribute some data, just shout.
(If anyone has any other useful dd-docs that arnt too big, I can post them there too)
Old 14-Feb-2006, 21:32   #7
domski's Avatar
I've always used 2 long lines - direct from the master cylinder to each caliper - no splitting required.
Too fiddly to split lines and find somewhere to tidy it all away.
Also if you have 2 long lines, it's easy to take one away (and a caliper and disc) should you feel that way inclined - takes all sorts don't it!
Old 14-Feb-2006, 21:36   #8
domski's Avatar
I should just like to add...
That's the way I would do it, if I didn't have a pit bitch called Chass
By the way we're sponsored by somebody who does Goodridge, and I thoroughly recommend that you buy some (although I hear HEL are good too)
Think that keeps everyone happy
Old 14-Feb-2006, 22:49   #9
AK's Avatar
Dom, thats exactly what we have done on the Snot - 2 lines.
Griff, the lines dont have to be braided, they just give a stronger feel, as they are a stronger pipe.
Mark at MHP uses std rubber ones on his R6.
C
Old 14-Feb-2006, 23:05   #10
Griff 64's Avatar
Thanks everyone so far
Ali, do you mean the catch tray was drilled in the bottom inline with the fairing nuts and it all sandwiched together.
Can you confirm standard gearing is 15/46,mines a early bike.
Don,t shout at once but on my 900ss road bike the gearing was vastly improved by going up 3 teeth on the back so lowering the gearing/making it shorter.
So everyone is making the gearing longer to race by reducing the back cog for the track,because...................the lighter bike/power to weight means it can pull more?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:29.
