Old 15-Feb-2006, 00:12   #1
loverobot's Avatar
gearing on a 95 600ss
can anyone tell me the standard sproks and chain on a 1995 600ss??
I have a 44T rear sprocket at the moment?
The frame number is 0022777
I am very confused by apparent gearing suggestions - B and C have suggested totally different sprockets front and rear ?
[Edited on 15-2-2006 by loverobot]
Old 15-Feb-2006, 09:12   #2
loverobot's Avatar
and i have a 14T front??
Old 15-Feb-2006, 10:22   #3
mitchc mitchc is offline
Mood: busy!
according to the ducati parts list standard gearing is 15-41. This is also confirmed by my autodata manual.
chain is 520x98
Old 15-Feb-2006, 10:24   #4
loverobot's Avatar
is that for all models? the haynes book just says refer to manual!
if i go 'back to standard' how will it differ from 14/44?
Old 15-Feb-2006, 10:28   #5
15 / 41 is standard on all 600SS bikes, but it is over geared like most Ducatis.
14 / 41 is ok but I prefered 14 / 43 tbh.
Old 15-Feb-2006, 10:33   #6
loverobot's Avatar
if i go lower on the back sprocket what difference will this make ? ie higher / lower top speed?
Old 15-Feb-2006, 11:55   #7
Some interesting info here so u can work it out:
http://www.ducatisportingclub.com/xm....php?tid=19755
Generally - smaller front = accleration
Larger rear = accleration
small front + large rear = mucho accleration
much better article here (again look for Shazaams post - at the bottom):
http://www.ducatisportingclub.com/xm....php?tid=18755
Frank
Old 15-Feb-2006, 12:14   #8
loverobot's Avatar
so it seems my bike is at the mucho accelleration end of the scale at 14/44!
if i go for a 14/42 can anyone tell me the chain length? Thanks
Old 15-Feb-2006, 12:26   #9
You should be fine with your current chain.
I've run everything from 14 / 39 to 15 / 45 on my chain and it always adjusted fine. The wheel will be further forward than currently, but not enough to make a real difference, maybe 2 or 3 swingarm marks at most.
You may want to be careful with 14 / 42 though - this is a 3x ratio, which means that the chain and sprockets will meet at the same place every 3 revolutions. This will cause increased wear - because it meets so often. You may see premature chain wear.
I'd be tempted to go for 14 / 41 as this doesn't mesh the gears as often. There's only a 0.1 difference in the output ratio, but it will increase your chain wear so it lasts longer.
HTH
Old 15-Feb-2006, 12:27   #10
loverobot's Avatar
thanks a lot antonye
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
