Old 16-Feb-2006, 15:32   #1
the old man's Avatar
Asymetrical exhaust?!! Am I a NUMPTY?
fitting brand new DP (Termi) exhaust to 900Sie and the right can / link pipe is too long - bolt hole in silencer bracket won't align with right footpeg carrier - if i shortened the link pipe (the short length of pipe that slides into the original manifold) about 10mm it would line up (left can went on OK). (the cans slip into the manifold like the standard cans - ie., no clamps like later monsters seem to use).
looking at the standard cans the right link pipe seems to be slightly shorter than left.
this all implies that the manifold where the cans slip in is asymetrical. has anyone else noticed this, is it me?
NB i've loosened everything, checked the obvious etc and it all appears cosher.
Old 16-Feb-2006, 17:20   #2
itexuk itexuk is offline
itexuk's Avatar
Mood: Great
Have you loosened the two bolts on the silencer bracket, they have about 10mm play left or right in them.
Old 16-Feb-2006, 19:15   #3
Unfortunately, yes.
The silecer bracket slots (where it bolts to the can) allow vertical / rotational movement. my problem is I need fore / aft movement. The bracket (where it bolts to the footpeg carrier) also has a slot but this is no where near long enough.
Old 16-Feb-2006, 19:22   #4
DSC Member AK AK is offline
AK's Avatar
Ian, as you havent been here for ages, can i call you a numpty anyway?
C
Old 17-Feb-2006, 20:10   #5
call me what you like - but i wish i could make sense of this stoopid exhaust.
it all squares up lovelly now but i had to trim 10mm of the r/h pipe where it slips into the manifold!!
aint monsters a laugh? always fancied one and am really chuffed with my new purchase.
got your Cadwell entry(s) in yet? can't wait ooooh!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:02.
