Old 20-Feb-2006, 22:00   #1
duc daz duc daz is offline
duc daz's Avatar
front brake
coming home tonight i found when i pulled the front brake it was making a rubbing noise as if the pads are not biting into the discs and slight vibration
Old 20-Feb-2006, 22:03   #2
duc daz's Avatar
just looked at the discs they look a bit glazed
Old 20-Feb-2006, 22:25   #3
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
You might have picked up some oil or grease contamination. Have you had the front wheel out lately or had a new tyre fitted at all?
Old 21-Feb-2006, 20:59   #4
Twinfan Twinfan is offline
Twinfan's Avatar
Could be some gunk in your callipers? I'd get it checked out matey...
Old 22-Feb-2006, 17:29   #5
Jiminy Jiminy is offline
Jiminy's Avatar
Mood: Very thirsty
Duc Daz,
What machine have you got - model/year ? Reason for asking is that I have a 749 Dark about 4 months old and it sounds like it's doing somthing similar. Although my problem occurs after I've stopped, as I pull away it sounds as though the brake calipers are not releasing properly and I get a graunching noise. I'm curious to see whether there's a theme here.
Jiminy
Old 22-Feb-2006, 19:14   #6
khu996 khu996 is offline
khu996's Avatar
Originally posted by Jiminy
Duc Daz,
Jiminy
Are you sure the frond end graunching noise wasn't the clutch?
Old 22-Feb-2006, 20:33   #7
duc daz's Avatar
it sounds like a sqealing noise as if the pads are made from wood
Old 22-Feb-2006, 20:35   #8
duc daz's Avatar
my bike is a 999 bip grey swing arm .and its not the clutch because it happens when im free wheeling down my drive way
Old 22-Feb-2006, 20:37   #9
Twinfan's Avatar
Jiminy - sounds like it might be the clutch as Khu says.
Duc Daz - have you got glazed pads?
Old 22-Feb-2006, 20:39   #10
Twinfan's Avatar
Daz - don't ride it. Either strip/clean/check your brakes yourself or get your dealer to pick your bike up. Just out of interest, is it an '04 model?
