Old 20-Feb-2006, 23:03   #1
weeksy2 weeksy2 is offline
Wanted : teensy tinnnnny nut, front brake switch.
you know them little tiny nuts that hold the brake light line switch to the m/c ??? Well one of the little buggers hit the floor tonight when taking off the braking system. Removed the whole system for an overhaul, but obviously we're going to have issues putting it back. I will try a few places at w/e if none of you boys have one.
We're looking an internal diameter of about 1.5mm or so...
Old 20-Feb-2006, 23:39   #2
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
I have a switch on my DD bike which has had the wires cut off (it was like that when I got it) When I get to that part of the build I will put that bit in the bin (it's all extra weight) if you want it and that's two bolts just incase you drop another. Send me a SAE and its yours. I trust they use the same switch on the 600ss as on the other bikes. U2U me I will send my Address.
Mike
Old 20-Feb-2006, 23:42   #3
Mike
Fantastic... thanks mate.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:14.
