Old 23-Feb-2006, 15:24   #1
851neil 851neil is offline
Mood: need a bike...
Q for Phil911 - or anybody else come to that...
Phil, can you tell me which part you have used as the 'valve' that sits in the airbox on the return side of the corse big oil breather box ??
If it's an original do you have any ideas of what could be used to do the same job ??
cheers
Neil
Old 23-Feb-2006, 20:56   #2
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Here's a pic of the breather valve, located on the top left ...
Original part is referenced : 593.101.91A ... ( unknow availability ...)
Otherwise, you can use a valve from Mostro new generation ( black part which looks like a big screw ...)
You can dismantle the valve in two parts.
Design is quite similar to the original item ...
Old 23-Feb-2006, 21:23   #3
Felix Felix is offline
Yup, still available under part number 593.1.019.2A. Same part.
Old 23-Feb-2006, 21:27   #4
phil911's Avatar
GREAT --- Thanks for the updated ref. !!!
Old 23-Feb-2006, 22:19   #5
top stuff, thanks Felix...
I'll try and order one up tomorrow morning.
cheers
Neil
Old 26-Feb-2006, 18:55   #6
errrm, slight problem with the updated part number - the local Duc dealer is saying that the part is no longer available, they've ordered it for me but don't think it will appear.
damn...back to the drawing board - Phil what is the Mostro generation ? is it used on the 999 / 749 series ?? do you have a parts reference.
cheers
Neil
Old 26-Feb-2006, 19:13   #7
phil911's Avatar
cheers
Neil
Sorry Neil, I'm not able to tell you the exact Mostro generation, but I'm quite sure next 2001 ...
Old 26-Feb-2006, 19:53   #8
Neil, I am sure this part is still available. I'll try and find out tomorrow.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:06.
