Old 25-Aug-2003, 20:26   #1
stewmcc stewmcc is offline
Mood: happy as a pig in sh|t
sc1,2,3 whats the difference
i baught a pair of sc3's last year but took them off as they never seemed to get warm enough on the road, is this because they are the harder compound a. eg are sc1's the soft and sc2 the medium.
used some 208.s on a trackday and it shredded the edge off and was wondering for the next one weather to stick these sc3's on or not..
do they need tyre warmers or are they not gonna get hot enough on a short track session.
never really trusted them when i had them on for the road.
any ideas
cheers
stewmcc
Old 25-Aug-2003, 20:45   #2
Yep.....
SC1 - soft
SC2 - medium
Tim
Old 25-Aug-2003, 20:48   #3
cheers rattler.that l be why they seemed to never get hot on the road..or grip for that matter.so are hard a bit much for a trackday novice then.
cheers
stewmcc
Old 25-Aug-2003, 20:54   #4
The usual track combination for SCs is SC1 front and SC2 rear.
That way they wear at a similar rate, (less wear on the front) so you can replace both at the same time.
Tim
Old 25-Aug-2003, 21:10   #5
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Where do road going SC's fall, medium ?
Mine get hot just running around the block.
Jon
Old 25-Aug-2003, 21:20   #6
I think they're the SC3s.
Both the SC1s and SC2s are marked as such with a small coloured logo on the side of the tyres. I don't think that the SC3s are marked at all in this way.
Someone did say there was a SC4 - but I'm not too sure. But I reckon you should avoid these anyway!
Tyreman - one for you I think!!
Tim
Old 25-Aug-2003, 22:13   #7
Jon Jon is offline
Jon's Avatar
Thanks Tim, as you say they are not marked in any way, all I can say is they give me loads of confidence and suite me to a tee.
Jon
Stew, what pressure's are you running. I normally run 32f- 30r on track days, this allows them to warm up quicker and also gives a better contact patch. 36 -34 for road use, not that I do much of that at the moment.
[Edited on 25-8-2003 by Jon]
Old 25-Aug-2003, 22:15   #8
If they are SC3s.......
....you should get plenty of life out of them.
Around 100,000 miles I reckon!!!!
When I last binned it at Brands, I'm sure it was because I had a SC3 fitted on the rear and could not get any heat into it, despite lots of abuse!!
So I for one, would not use SC3s on the track - unless its just to get he bike out of the van!!!
Tim
[Edited on 25-8-2003 by Rattler]
Old 25-Aug-2003, 22:19   #9
Desmondo Desmondo is offline
Mood: :devil:
AFAIK SC3's/RS3's aren't made anymore so you're just left with the choice of SC/RS 1 & 2 now.
Old 25-Aug-2003, 22:23   #10
Jon Jon is offline
Jon's Avatar
Tim I'm looking at changing them after less than 200 road miles, 2 days with the CSS at rocky, one washed out track day at mallory and one trackday last week at rocky. The center of the tyre is vertually untouched but the sides are quite shagged with no way of telling when the carcase will show through.
Jon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:35.
