Old 15-Dec-2013, 19:45   #1
DAVEST205 DAVEST205 is offline
996 Modifications and Bike
I had previously advertised the below but a change in circumstances meant it never went ahead, well unfortunately due to lack of time and use and starting a family i've decided to sell my 996, beforehand there's a few parts to be removed from the bike andreturn to standard condition, initially gauging interest and if most of the below are wanted il go ahead sooner than later, i know some of the prices are at the upper end of the scale but then this reflects there condition, but i am open to sensible offers on some items:
*Magneti Marelli MT940B digital dash with full wiring kit and brand new speed sensor and external push button and brand new oil pressure/temp wiring kit and sensors, this is the backlit version. - £1200
*Termignoni 45mm exhausts in excellent condition - £350 or £300 plus standard exhausts.
*Ducati Corse Rearsets and gear/brake pedals in excellent condition (originally purchasedfrom Tom i, so not cheap copies) - £200 or £150 plus standard rearsests/pedals.
*Ohlins Rear Shock and spring in excellent condition - £350 or £275 plus standard shock.
*Ohlins Road & Track (R&T) FG43 Forks with removable caliper mounts and in excellent condition (can come with bottom yoke which has been powdercoated black and with 65mm caliper spacing) - £1,100 or £950 plus standard forks and lower yoke (if req'd).
* CM Composit Carbon Air Intakes in excellent condition, these come with filter runners so standard filters can be used, airboxclips and indicator mounts - £275 or £235 plus standard intakes.
* Ducati Performace Carbon Front Fender in good used condition (recently relaquered) - £150 or £120 plus standard fender (red).
* CM Composit Carbon HeatShield in good used condition (recently relaquered) - £50 or £40 plus standard heatshield.
* Carbon HeelPlates (Corse Type) in good used condition (recently relaquered) - £60 or £50 plus standard heelplates.
* Genuine Ducati 998FE Single Seat Unit (Red with Italian Flag and Campione Del Mondo Superbike text) in excellent condition - £350 or £250 plus standard biposto unit and seat pads (red).
* Tecnosel Seat Pad in very good condition - £150
* Ducati Performance Carbon Hugger and Chain Guard in good used condition (recently relaquered) - £150
* Brembo P4Calipers, with pads and lines in excellent condition - £275 or £190 plusstandard calipers/pads/lines.
* Renthal Quick Release Rear Sprocket Carrier in excellent condition (stops cush drive fouling hub) - £70.
* Ducati Performance Carbon Fuel Cap (lockable) in excellent condition - £40 plus standard fuel cap
* FIM Dual Injector Chip (cures hesitation/stutter) - £70
* Stainless Pro Bolt Fairing and Screen Kit - £100 plus originals (£142 new)
* Stainless Pro Bolt Fork Pinch Bolts Kit - £12 plus originals (£16.37 new)
* Stainless Pro Bolt Clip On Bolts Kit - £25 plus originals (£33 new)
* Stainless Pro Bolt Brake and Clutch Pinch Bolts Kit - £7 plus originals (£10 new)
* Stainless Pro Bolt Footrest Hanger Bolts Kit - £10 plus originals (£14 new)
* Stainless Pro Bolt Sprocket Nuts Bolt Kit (new in bag) - £15 (£20 new)
* Stainless Pro Bolt Top and Bottom Yoke Bolts Kit - £15 plus originals (£20 new)
* Stainless Wheel and Sprocket Nuts Kit - £55
Any standard items to part ex must be in good condition.
Bike will also be available: Ducati 996, 2000 with silver frame and marchesni 5 spoke wheels.
Circa 14,000 miles (will need to check when next at workshop).
Acumen Cat 1.1 alarm and immobiliser.
Has a current MOT but is currently sorn.
Full service history and whilst i've owned it this has been done by Pro Twins and Carl Harrison.
Is due a belt service and if asking price given i'll arrange for Carl Harrison to do this.
£4,000
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:58.
