Old 26-Feb-2006, 20:50   #1
duc daz duc daz is offline
duc daz's Avatar
race ECU
had my termi,s fitted last week and it ran ok a bit of popping her and there but other wise ok .ive took it to JHP coventry to have the ECU chip fitted and set up .what gains will i get from having this fitted
Old 26-Feb-2006, 21:00   #2
Er.....if its fuelling weak and they set it up it wont blow up.........if its fuelling rich before they set it up low on power, 20 miles to the tank........
Have a dyno run and set it up properly its the only way to know its right!
Old 27-Feb-2006, 20:40   #3
duc daz's Avatar
want they do that any way
Old 27-Feb-2006, 21:01   #4
your asking what gains by having the job done properly.......... and you get peace of mind its running right!
Old 27-Feb-2006, 21:34   #5
duc daz's Avatar
whats the difference between standard ECU and the race ECU
Old 27-Feb-2006, 21:45   #6
Twinfan Twinfan is offline
Twinfan's Avatar
Different fuelling map and ignition timing.
Old 27-Feb-2006, 21:53   #7
duc daz's Avatar
and what gains will i get
Old 27-Feb-2006, 22:05   #8
ffs................
whats the point in having the wrong fuelling? its about making your bike work to its best ability at all revs.....The fulling maps contained on any chip cpu, are just a best guess. By having a rolling road set up, makes your bikes fuelling map unique to your bikes requirments to run at its optimum level without fear of being weak at some point in its rev range , or indeed rich.............
You could also achieve this nirvana by leaving your std cpu in and fitting a pc111!
od dont i hear, what gains will i get...................
Old 01-Mar-2006, 21:11   #9
duc daz's Avatar
Old 01-Mar-2006, 22:21   #10
well youll certainly get full left hand control of the circumflex widget. This will pull centrally on to your 14 tooth front sprocket which relates in general terms to the balance of both idle screws and the idle gear................giving a 120% benifit!!
Clear now?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:05.
