Old 27-Feb-2006, 15:21   #1
Maxypriest Maxypriest is offline
Mood: Fed up I'm not racing. :-(
Fork question - black tube length?
I have bought a ‘pair’ of forks on fleabay. Cutting a long story short, they have different spring rates and the black plastic spring tube is 14.7mm on one and 13.something mm on the other !!!
New springs have been acquired, but what is the correct length of black plastic tube for 40USD non-adjustable 1996 madzzoggie forks in a SS?? Help would be appreciated!
1 month to go.....
Max
#27
Old 27-Feb-2006, 16:07   #2
domski's Avatar
I think those ones need a 24" steel rod inside em
Old 27-Feb-2006, 17:15   #3
Domski,
I was expecting something like that!!!
"See you on the road Domski!"
Priest.
Old 27-Feb-2006, 18:27   #4
The answer to the question is 148mm or 14.8cm as your figurs look a bit confusing
Old 27-Feb-2006, 18:52   #5
domski's Avatar
Originally posted by Maxypriest
Domski,
Priest.
I have a reputation to uphold - glad I didn't disappoint you
Old 28-Feb-2006, 14:21   #6
Skidlids,
Thanks for the measurements (and correction too - apologies).
I have some pipe (white plumbing stuff) that has the same OD and ID at the black pipe, so I’ll be sawing that up this weekend – unless the tube has to be made from something else…? (not lead Mr Domski)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:30.
