Old 28-Feb-2006, 11:07   #1
Fastfasulli Fastfasulli is offline
Front Brake calipers
Hi,
don't know if anyone can help here but I'm thinking about converting to double disc on my 1995 Monster. I have been offered some 916 calipers of the same year. Anyone know if they will fit my standard forks.
Franco
Old 28-Feb-2006, 11:23   #2
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
I'm sure they will. Just check the caliper mounting points are 40mm spaced...
Old 28-Feb-2006, 11:29   #3
Thanks Tonio.
My technical ability is not up there so just to be anal about it where do I measure from and two exactly.
Old 28-Feb-2006, 11:53   #4
domski's Avatar
Centre to centre of each hole.
Old 28-Feb-2006, 12:02   #5
Gentleman, thanks
Old 28-Feb-2006, 12:14   #6
Yes they will fit defo no need to measure and don't pay more than £50 for a pair.
Old 28-Feb-2006, 12:24   #7
Thanks.
Old 28-Feb-2006, 22:06   #8
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
Don't forget you'll need to change the master cylinder as well to one suitable for twin discs (the standard one has a smaller bore).
A second hand 916 / 748 style master cylinder should set you back around £40 ish second hand and does nicely.
Old 28-Feb-2006, 22:55   #9
As Zimbo says you should upgrade the mastercylinder as well, most are going the remot reservoir route but a cheaper option is to use one off a twin disc Monster or 750SS.
You pays your money and makes your choice
Old 04-Mar-2006, 22:43   #10
Cool thanks.
Hmmm...just got landed with the bill for the work on my bike....might have to go for the cheapest option possible!!!
I have definyiely won the calipers on ebay so that's good - will look around to try an find a 916/748 option as cheap as possible now.
By the way I had my first ride of my (more or less) today at Snetterton. Prob not the best track to start - especially with Arctic winds and snow swirling around later in the day but one thing I noticed is that even with resprung forks the front was ...errr...squidgy. It makes me wonder what it would be like with more powerful brakes now?! Could anyone tell me what weight fork oil is being used generally - I have a 1995 monster which I think has Marzocchi forks.
cheers
Franco
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
