Old 02-Mar-2006, 13:35   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Clutch slave
I'm looking to replace my clutch slave cylinder as there is signs of leekage.
Any ideas on well made cylinders, cost and where to buy?
Dave
Old 02-Mar-2006, 13:44   #2
Dibble
Dave
If you are happy with the clutch lever action and don't need a lighter one the quickest and best option is an uprated piston with improved seal, available from Nelly www.cornerspeed.co.uk or if you need an uprated one the Cornerspeed ones a top bit of kit and he'll do you a deal.
HTH
Old 02-Mar-2006, 13:48   #3
If you want looks as well as function you can go for a bling upmarket cylinder. STM are lovely bits of kit but people like Cornerspeed, Tecmoto, JHP and lots of German companies on eBay all do the same sort of thing.
Most of the aftermarket cylinders will also promise a lighter clutch action. They do this by having a greater bore, obviously this means that for a given volume of hydraulic fluid that's pumped from the master cylinder the stroke of the slave piston will be reduced so they need some pretty careful bleeding through if they're going to move the clutch plates far enough apart.
In my case I tried an STM cylinder but it was clear that the master cylinder on my bike was never going to pump enough fluid to prise the clutch plates fully apart and it dragged like hell. After one trip to Melton Mowbray and back I gave up and sold it to KeefyB who put it onto one of his bikes. I got a 30mm one which was too much (works well on a Multistrada or 999) could have been better off with a 28mm one.
What I ended up with was the upgraded slave cylinder from Ducati - the one that looks like it's got a big Torx headed bolt in the centre. Much better made than the earlier ones and not prone to leakage.
[Edited on 2-3-2006 by Jools]
Old 02-Mar-2006, 13:57   #4
dave996's Avatar
Mood: Fed up...
Cheers for the info guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:06.
